Battery life?
I think the battery life needs some improvement. coming from Note 4 with 3220 to v10 with 3000, i dont think i should notice a 5 hour difference in battery life, considering my settings and usage are the same.
The battery just isn't as large but there shouldn't be a 5 hour difference.
Are you referring to Screen On Time or Standby time?
There is usually a High initial Screen On Time with a new device as we transfer info, set it up and generally play with it to see what it can do.
I'm sure the S.O.T. is much higher now than it was with your previous phone right before you got the V10.
It may not last as long as a phone with a 7% larger battery.
But I doubt it will be 5 hours worse.
I'm coming from the Note 4 and 5 and I would say the battery life of the V10 is on par with those phones....maybe slightly less. With the Note 4 I could get through a full day and have about 30% battery by the end of the day, the Note 5 was slightly better...maybe 35% and the V10 its usually 25-30%. A typical day for me is browsing the web(40%), emailing(10%), watching videos(20%), checking social media(10%), listening to music and playing a game(20%) or two.
But battery life is going to vary depending on what apps you have running in the background. I use the battery doctor app to help with that.
rixq52
