Battery Replacement Process on S9?
Just enjoy your phone and don't worry about the battery. I never do , and have never had any battery problems.
several times recently, i see the charge on my s9+ at 5% or so going into power save mode. i have charging pads in several rooms and i lay it on one quite often. i check the usage by application and don't see anything too alarming. Twice I found it on the pad, hot, screen lit with some app on, and bat still at 20% after more than an hour. Using all Samsung pads.
My S9 battery life seems to suck. I bought it used and it is my backup phone, that I currently use for sleep tracking and sleep cycle alarm.
Maybe that is just a huge drain.
When it gets One UI version 2, I'll likely daily drive it for a while. Maybe then I'll know more if it's the actual battery or how I've been using it.
Are you sure its fast charging wirelessly? Also sounds like some type of app is eating battery.
Good thinking!
I haven't checked my S9, but my Note 9 will not fast wireless charge, with the screen on.
I guess it's a 'feature'.
williestringfield90
