TheAssailant
- Jun 1, 2012
- 195
- 27
- 0
Usually radio mods are not included in a devs ROM it is a separate file.
Did you flash the jb bootloader when you moved over for ics? I have noticed a lower signal since I switched to aokp p4 but I know it should not be the ROM buy who knows I jump on any new radio that helps the signal.
I used Bugless Beast and kept stock bootloader. My radios are the same as before. It came with all the Google Apps AND Wallet.
IMM76Q isn't a radio update. If it was, it wouldn't be less than 1MB.
Sent from my VZW Galaxy Nexus using Android Central Forums
