Try going into the phone's settings, under sound. There's choices for the sound enhancer. There's the beats (which you can also select three choices, up in the upper left corner , which are urbeats, solo beats, and other) or try the non beats selections as well. Personally, I tend to enjoy the "sweatener" one, But driving in my truck I still toggle on beats urbeats mode. Makes it sound fuller at low volumes. Like the old "loudness" function on older stereos. I don't have to crank it up as much. Also noted that when using the 3.5mm aux cable, make sure your media volume is up on the phone. I have mine at about 80% so my stereo doesn't have to be at 17 to sound normal. In fact, I rarely have it past 12, unless I have all my windows down and running on the freeway.
sent from my wicked EVO ONE using mind beam.
