Best Case for Incredible
Best Phone Case Or Holster
Hey I was thinking about buying a case to protect my incredible in my pocket or maybe a holster any suggestions???
I use an Invisible shield and had the red snap on case from Verizon. It was damaged so I returned it, but it is smooth like Seidio (which I think makes great products but are too $$$)
I'm currently using the black silicone case and it's worked out perfectly... See here.
I'm using that case and the Invisible Shield screen protector from Zagg. Both are working great, IMO. The protector is barely noticeable (hence the name) and the case is very thin yet seems to protect the phone well. I'm very happy with both purchases.
That being said, I'm pretty sure there's a thread or two already dedicated to cases/accessories, so try searching if you want to see what others have to say.
which case is the gradient one?
In my thread called Protection, Protection, Protecion :) I showed a pic of their red snap on case (with a cut out on the side for no reason)
I am using the shell case from Verizon without the holster (front pocket). I am also using a screen protector from Verizon (covers the LCD portion only so therefor no pealing from case interaction). the shell case (I believe from Amzer) pops on the back only, is very thin (almost can not tell it is on) and extends out in front on either side to help protect the screen (if it were to be dropped on a flat surface or laid on a table, etc...). I rarely take it off and may just be the last case I buy. I had the clear (hard plastic) snap on case but I couldn't stand it. Lint always getting underneath and if I dropped it, it would pop off into two pieces anyway. The clear case may have been perfect for, lets say, women who kept it in their purse but the lint collection drove me insane. I strongly recommend the Amzer HTC Droid Shell + holster case/combo. If your a belt clip person you can do that and if you are front pocket you can do that as well.
The best case would be the Vaja ivoloution but they still haven't received enough requests to make one. The Seidio case will also be good if they decide to make one...
It sure is taking a while for Incredible accessories to be announced.
Just tried to find it online and no luck I bought it in store here is a picture of it :D
Lassi876
