Best external battery options for HTC One??
Check out the mophie juice pack for HTC one
I just bought a mophie juice pack.. I'm very impressed! Charges phone while you are out and about. Saved me finding a charger
Sent from my HTC One using Tapatalk 4 Beta
I have the Mophie Juice Pack on my (silver version) and I don't find it too big, bulky or annoying. It is nice to have a full battery ready to do at the flip of a switch.
I'm trying to decide between anker and ravpower. Both seem to be popular and frequently go on sale.
At first the anker product I bought was working well with my one but for the past couple months I seem to be getting pop-ups on my phone saying the external charger not compatible when its plugged into my phone. Is this a concern cause I just ignore it and keep charging it with the anker.
I'm getting this problem now. Anyone recommend anything better?
You may get a defective one. Call anker and see if they'd exchange one for you. You can go with RavPower also. I've been using their 14000mAh charger and 5-in-1 filehub. Not any problems so far.
Strange, I started to get this message too on a unit I've used for months. As I use the battery case infrequently, as best as I can recall, it started right after the last software update. Not sure what to do either.
I love my black Mophie! 38hrs is my record. No cords and on the daily I get 17hrs and use a slim line clear case.
I just got a Mophie Powerstation Duo for Christmas. I've noticed though, when using it with the Mophie cable, the One will cycle in and out of charging mode for several minutes before charging. Sometimes, one port will do this non stop, so I move the cable to the other port, it does it a few times, then charges steadily. Has anyone else seen a similar situation?
I have gotten this warning message on HTC ONE as well, using a UNU 5000mAh, 1 amp high output battery.
Is this a way for HTC to promote its own battery Charger or will this cause problem with HTC battery not replaceable?
What is a good reasonable priced option? or one that goes on sale at Amazon?
LordDAXVader
