Best Galaxy Note 4 Tempered Glass Screen Protector
My Supershieldz has the halo. Not so bad on top and bottom, but definitely on the sides. And its the smaller one that only covers the viewing area. Not bothered by it much, but its there.
Mine has a slim one on the sides too but the top and bottom are good. Not worth dropping any extra money to gain .5mm more of coverage. Hoping for a decent solution. If someone covers the full screen, then the complaints of not case friendly will start
sent from my Samsung GALAXY Note® 4
Picked up the iloome Flex (which took a week for delivery, oh well) and put it on last night. There's not a full halo effect, but the entire right side the of protector is a tad lifted. Maybe last a couple of months...or a couple of weeks. It sucks. Anyone else have any luck with iloome's Flex? I thought because it took so long to come out, they corrected the issues. Or not.
Have had my iloome flex on for a week or so with no lifting or falling off issues. There is a halo all the way around but its less than a mm wide and does not come onto the screen. The halo is only on the tiny black space all the way around the screen and not on the actual visible screen. Ya, it sucks, but I cant even notice it when the screen is on. This is the second screen protector that I have tried for a phone that I have had less than a month so I am just going to keep it because I am tired of dealing with it. I would only buy a new one if someone comes out with one with curved edges that will go edge to edge.
we are on the same boat, its a good thing that I have a friend who works as a technical support for screen protectors, I just let him do the stuff
Which would you recommend in light of this thread?
I'll have to go with the Spigen Glass tR.
It's expensive but out of the el cheapo Chinese eBay crap that I've tried, it's the only one that doesn't leave fingerprints and have a smooth feel to it.
But there might be some that can rival these features without breaking the bank like Zerolemon so hopefully someone here has tried that.
The Spigen Glass tr. isn't currently available but some installed the original that was pulled with no halo so their revised one hopefully will be a good choice.
My words exactly. Just got mine put on and it's definitely smaller than it should be. Are we sure they're not just note 3 protectors re labeled as note 4? I have no idea bc I'm coming from a s4. Just a thought
It would be wonderful if could just purchase a nice tempered glass screen protector that would work perfect on the Note 4. :'(
I've also had mine on for a week or more and, so far, no issues and no halo. The only negative I see is that the iloome flexmate is a little softer than my previous Mime screen protector on my retired Note3 and already has some very minor scratches.
I'm using the iCarez film protector and definitely don't recommend them. They are fingerprint magnets and the S Pen has a great increase in resistance. That said I'm leaving it on until a glass protector becomes available.
I have one I bought it from amazon... It was inexpensive but worth it to me... Just because a screen protector is expensive don't mean it's better than the inexpensive ones.... I have no issues with it...see screenshot...
I left the plastic on the front of the screen the phone came with which worked pretty good so far. I bought a bear glass protector and yet to put it on yet. A little scared of doing it though. I have a cheap TPU case I got and it lifts up the edges of the OEM plastic. Planning to get a different case eventually but right now pickings are kind of slim. Thoughts?
Nazeer zaheen
