Beta Program for One UI
Just received beta update on t-mobile unlocked. Registered for beta yesterday but received update just now after manually checking for it.
I just withdrew from the program and rejoined and I now am getting the download
I have read people saying they have a bunch of force closing of apps, anyone else experience this? I always go into Recovery and Wipe Cache a couple times after an update and I haven't seen any issues with apps force closing. There was one time where the Edge Panel was massive like it was magnified but after closing all apps and turning the screen off it went away and hasn't came back yet.
I just hope the release version of one UI 4 doesn't cause degradation of battery life. Every new android update always crap on the battery life
Anyone that's running the beta now? Any comments on? Good luck and if it's working properly
No app issue yet
It normally takes about a month or 2 (from past experiences) to get the Good (*) apps updated, so you may be out for a while. :(
I'm just going to hang here with my good luck intact. I've been using the Pixel 6 Pro anyway as my daily so no worries or rush on my end lol
You are all brave souls...
Fine line between brave and stupid... it all depends on the ending. :P
I do have a question. In order to flash this Beta, you have to flash the Unlocked Firmware. I get that, but being on T-Mobile, would there be any issues doing so? Would services and apps work as intended?
No issues except this pop up continuously showing up when moved to any other screen other than home screen which is annoying. Tried deleting and re-adding other screens and widgets but didn't help.
I had that for Samsung pay , go to that app clear data and force stop it
liquidsnake757
