Beta Program for One UI
Fine line between brave and stupid... it all depends on the ending.
I do have a question. In order to flash this Beta, you have to flash the Unlocked Firmware. I get that, but being on T-Mobile, would there be any issues doing so? Would services and apps work as intended?
Its beta so anything possible something might not work but if you flash and expirence something can flash abd go back
This is why, as I said above, not only do I not participate in the Beta testing, I also won't update until EVERYTHING in GoodLock is supported in the final release... which usually takes months.
Thats true
I used to use good lock for home up and multi tasking. With one UI 3, don't need good lock with features I wanted natively baked in advanced section. So, uninstalled Goodlock for good on my ZF3 and Tab S7+, and it's been sometime.
Im like between testing beta 12 on the fold3 and setting the pixel 6 pro up next few days lol
The update fixed QuickStar after you also update the app, that's one of the main ones I use.
Hey man, I'm not doing the beta though saw on Good Lock the update for QuickStar as well though on trying to update I don't get the option to do such... attached a screenshot. Any thoughts?
Thanks
Thanks
Hey I don't understand your question?
liquidsnake757
