Better keyboard?
Swype Beta 1.3.5 10176 - working awesome on the Sprint S3
Much better than the Swype included with the phone.
The new SwiftKey Flow beta just released today and and is pretty smooth. I'm using it to post this. Once I get used to șwiping, I'm sure I'll love it. Looks like it'll be a free upgrade when it comes out of Beta.
Sent from my SPH-L710 using Tapatalk 2
Ok. I love it. Still learning about it, and getting used to swiping, but I really love it. And the predictions seem to have gotten better.
Anyone else using Flow?
I'm using it. Right off the bat, I wish it would give options for words after swyping. So if I'm not accurate enough, it just throws out whatever it thinks I meant to say. I wish it would give options like regular swift key would. I loved using Swype and I wish it would meld the functionalities.
Also, I notice that the swiping doesn't work with some apps. Has anyone else experienced that problem?
I know it sounds like a broken record but I too use Swiftkey 3, it quickly learns your typing style not to mention its' prediction rate (what your next word is going to be) it is spot on the majority of the time. Highly recommend it!
Try setting your typing style to Precise (under Advanced settings). I also recommend increasing the time for Long-press duration. And it may take a few days to "learn" from how you use words, etc.
motoJunkie1
