Bluetooth Issues after 5.0.2
I went to the Korean version to get Bluetooth back a couple of weeks ago.
I have no update available that people are mentioning here and I'm in the U.S.
How do I get back on the upgrade path so I can get the newest download?
Great question!!
I have been reading the posts and if Icaught it right the new update is called 5.0.2 which sounds like trouble to me (the last one was named the same). Is there another way to distiguish it is the right one?
Also is this update available by going into settings=>General Settings => About Device => Software update?
Currently I have auto update turned off. I could check for an update but at this point I am unsure until I speak with the folks at Samsung and (AirTurn - my blue tooth device).
You guys are the greatest for sharing (thanks) and apprecaite your response omn this too.
Ciao!
You don't need to do that long route. Just download the OH2 from Sammobile and flash back the US version.
This is the Korean version
Flash the US version OH2
Then here I am
Great question!!
Update should be in sequences if you're right now at Kitkat 4.4.2 NK1. The next update should be Lollipop 5.02 OF4, then the last one is updated to OH2, the latest that fix Bluetooth issue.
The fast route is Flash straight from Kitkat to Lollipop 5.02 OH2 by downloading from Sammobile, but I think you're not comfortable to do this way.
Thanks this is gret information.
OK I am lazy (I guess).
What Ireally want is for the system to do a system update and have it work properly (Settings =>Device Info=> System Update).
Am I wishing for too much?
Check the Auto Update in setting and let it downloads the necessary download file, then click Install when it's ready in your tablet.
There is no shortcut to jump to the latest firmware without doing in sequence except when using Odin to flash the latest firmware.
Hi Al,
Just back from vacation and catching up. This sounds like great news, but Im not sure how I check for the updates.
Would someone be willing to provide some "*****-proof" step-by-step instructions for me to get the update?
In setting, About Device, Software Updates, check Auto Update. It will download any new update available.
If no update , you will see the message :" The latest updates have already been installed " when touch : " Update Now ".
Ontario, Canada - just received the update and I'm pleased to report that my AirTurn pedal is working! thank goodness and about time!! thanks everybody for your updates, it helped me be more patient when I could see it was slowly rolling out and others were getting it. Take care all,
Also in Ontario and got the update. Logitech keyboard, Microsoft Mouse and generic (the Source) Bluetooth keyboard all working.:D
My Keyboard is back! Never doubted Samsung for a moment ..... emmm ... well maybe for a moment ... lol From New Brunswick Canada
Lucky Koreans, lucky US-citizens, lucky Canadians, your updates are there.
Now you first install, then wish us luck that the Dutch and Swiss updates are to follow soon.. There's a whole continent depending on those two.
Great question!!
Ciao!
Yes. Got mine tonight and it is fixed.
No you are ok. I just waited for the update and ran it.
Can someone please tell me if there's a way to keep the on screen keyboard from coming up everytime I select a text box. Trying to use my tablet to do excel, but everytime I go to enter something in, the on screen keyboard comes up and blocks out over half the spreadsheet. I have googled this and gone through several threads to find out. I came here because I just got the keyboard working with the last update and everyone else here has been so incredibly helpful.
I have upgraded to 5.0.2 and Build Number:
LRX22G.P900UEU1COH2
I also confirmed before upgrading this is the build that fixes the Blue Tooth Issues.
I did this in the US and all worked great.
By the way my device is a AirTurn BT-105 Foot Pedal!!!!!
Samwise73
