I drive a truck for a living and having BT is a must. BT works but here's my issue...
I've used my Motorola CommandOne, Blueant Q2, and Samsung HM3300 and all have the same issue so it's believed to be a software problem. As soon as I hit the button for voice commands, the screen for VC blips on screen for a split second and half the VC prompt is cut off coming through BT. I have only a 50/50 chance of it working the first time. Usually it will work on the second try but annoying as hell. I disabled beats, and the lock screen thinking it might be the issue but it's not the case. Now, this happens every time I use BT and if I reboot it works perfect the first time I use it but after that, what I described happens.
I've tried using Dragon... which is awesome BTW and it works 100% of the time. The only issue is that when you use it, it stays active and the screen doesn't shut off killing the battery. Does anyone know of a fix?
