Bluetooth options reset for paired device
  • Thread starter Android Central Question
  • Start date
A
Hi, I recently bought a car stereo so I can sync my music through Bluetooth, amongst other features. However, I have an annoying problem :/
There are 3 syncing options that I can use with the stereo. The Contact Sharing never disables itself, but the other two disable themselves if I break the Bluetooth connection by taking my phone out of my car. Is there any way to make the other 2 options stick like the contact sharing option? Its extremely annoying :(
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
To which options are you referring? Phone calls and Media? If so, let the phone connect to the car, then turn them on (in the Bluetooth page, the gear to the right of the car connection). It might take 2 or 3 times before they stick.
If it's other options, please join the Android Central community so that you can keep the conversation here instead of starting another one each time you post. That gets messy, when someone has no idea what you said in some other thread.
thephilster001
