- Nov 25, 2010
- 15,958
- 2,753
- 0
I just updated to 4.0.0, but the Baseband version still says EB13. Is it correct?
You need to flash the modem then the baseband will change.
Just loaded up this rom and i love it with one reservation. Everything is working with the exception of USB Mass Storage Mode. "Connect USB Storage" does nothing for me.
Anyone else experiencing this issue?
Can we flash the EC05 modem via Odin and stay on an EB13 ROM? I currently switch between ACE and Baked Snack 2.1...
I can't completely confirm this 100% but I did try it once when I was attempting to flash the "leaked" EC05 stock ROM from Bonsai. Anyways..
I flashed the EC05 modem, and had issues so I went back to CWM to flash ACE or something else to get up and going again and when I tried ACE it aborted installation at the modem install part of the script. I'm guessing because ACE was trying to push the EB 13 modem when I had the EC05 modem and it caused an error and aborted the installation. Anyways I couldn't flash any ROMs at that point and ended up using Odin to get out of it because I had no CWM backups at that time to restore to and I'm not sure if that would of even made a difference with the modem being flashed.
Bottom line, if you want to be a "test dummy" then go ahead but I would stick with EB13 modem on EB13 ROMs until you hear different.
I don't know what the difference is but after flashing the EC05 with Odin my phone still says EB13 and I'm not sure if that's what it supposed to say or not?!
Can I flash this ROM straight from CWM if I am running ACE?
Only the baseband version should change when you flash the EC05 modem. Build number will still remain as whatever the ROM builder has put in there
