2CupsWithString
passionately curious
- Jun 1, 2010
- 2,760
- 412
- 0
So just flash boot.img and then reboot? Or should i start over?
You can give the boot a go by itself.
i think from an ruu zip... i have so many pc36imgs laying around, its hard to tell, i should have been more organized going about this, but its hard when you want to see if the next thing you try is going to work.
I understand.
If you're on hboot .76, I would load the boot.img from the HTC Engineering software build for the evo. Then do the same with that system.
Downloading now, I'll try to run it first i guess.
Anyways, I've never heard of unzipping an exe. How does that work? Can I actually open an exe in 7zip/WinRar?
ohhhh boy.
I've screwed up now.
I can't see my screen... its a dark grey screen... whenever the screen used to be white. when i go into hboot... its a grey screen again, like the entire thing.
All I did was run that exe. I'm freaking out.
manwiththeevo, actually I had flashed MIUI after CM7 nightly was acting strange. About two hours into MIUI acting normal, the thing just suddenly crashed and reboot, and thats when it went into the cycle. I hadn't flashed the rom for a couple of hours when the boot cycle actually started.
i haven't been able to get adb to work since i've started all this, it just says "List of devices attatched" and then its empty
