Bottom Icons NOT Disappearing when Scrolling Between Pages - HELP
haha your just like me.... i had a samsung fascinate that had a marketplace issue. i could of very easil just rooted and flashed a new rom and it would have worked but i worked on that thing for weeks!!! never could fix it and it bothered me so much i sold it on ebay ( with issues disclosed) and bought a droid x...lol
getting off topic though...good luck again
Haha, yep...it's an issue. I'll try to fix it and see if that helps out my OCD. I could see me trying to switch phones even though it works fine with LP. Thanks again for all your help!
I would be suspicious of the two apps you downloaded right before this issue surfaced. Try uninstalling them, do a battery pull, and see if things are back to normal. If so, re-download the two apps ONE at a time, and check for the dock problems after each install. You seem to have an app conflict going on.
PS - If you do find the culprits and resolve your issue, I HIGHLY recommend Launcher Pro Plus! It's great!
Thanks for the advice! I tried that out and deleted both of the apps that were downloaded before all this happened, rebooted, and nada! I'm definitely at a loss. Im actually using LP right now because that issue is really annoying me. I can't figure out how to fix it. Two forums haven't been able to fix it yet. Hopefully I can avoid the dreaded factory reset. Thanks again.
definately a corrupted file somewhere... could be from an app installed. so choices are either run LP, or factory data reset... although keep in mind you can backup all your apps with titanium backup and google will back up all your contacts. so factory data reset isnt all that big of a deal... realy only thing you will have to configure again is your widgets and homescreens...
So I've got Z4 Root on my phone that I downloaded before it got taken off the Market. I also downloaded Titanium Backup because it's come to my attention that I'll need to do a reset. I'm not rooted yet, so I guess I would have to do that. But I'm not sure how all this would work. If you could give me a few quick instructions, it would be greatly appreciated! Thanks!
Thanks Cyber. I'll check that out after work. Hopefully I can get her back to full strength.
reblkari666
