brief battery percentage circle when removed from charging...
marklyn
15
I like seeing the brief battery percentage circle when my phone is removed from charging. Is there a setting that can be turned on to see the same battery percentage circle briefly appear when I plug back into a charger?
No, but you can set the phone to always show the percentage instead of the partially-filled bar (a the top). Settings > Battery.
Thanks but I already have that, just wanted it to display the same battery percentage bubble.
I see the bubble briefly when I plug it in. It usually stays on long enough so that I can see that fast charging has kicked in as well.
Go to settings then accessibility then visibility enhancements then turn off remove animations
Luca-Taal
