- Oct 26, 2010
- 66
- 3
- 0
Sweet. Thanks a ton man. It's nice to know helpful people are still out there these days. I'll wait for your results.
What baseband (modem) version do you currently have loaded?
If you really wanted to get back as close to stock as possible, this should work:
First, download this: http://adrynalyne.us/files/kernels/DL09_stock.zip This is the stock DL09 kernel.
Next, download this: http://gunsforgeeks.com/Fascinate/DL09_stock.zip This is the stock, bloated, odexed DL09 system.
Put your SD card into a reader, copy these over, reboot into CWM (assuming you have it installed) and flash both. At this point, you should be on stock DL09. You'll have the SuperUser app installed, but you can always long-press on it and delete it.
You can either stop here and fairly safely assume no one at a Verizon store will notice any system/baseband mismatch (if there is one), or you can do the following:
Awesome man. Tons of help and good info. Thanks so much for it.
So basically, do this, and leave it at that?
No problem!
Yup, flash the DL09 kernel, then the ROM, wipe data, cache, dalvic cache and reboot. Once booted, install Root Explorer (or another file manager capable of working with the /system partition), go to /system/app and delete Superuser.apk, then you'll pretty much be totally stock DL09. You can flash or not flash the stock recovery, nothing will give the CWM recovery away unless they reboot it in recovery (highly unlikely). If you did decide to flash the stock recovery, remember, it's a one-way trip, since without Odin, you'll never be able to put CWM back on.
Also, make sure you remove or clear certain files/folders from your SD card - the Voodoo folder, the Clockwork folder/backups, etc. I can't imagine they'll actually notice the modem version, since nothing else will give anything away at all.
Well here goes nothing to see if it works.
Cool, let us know how it goes...
I assume it's not an issue since it hasn't come up yet, but hopefully you're currently using Clockwork 2.5.X... because that's what all these zips require. If you're on CWM 3, I'm not sure how to go back to 2.5 through CWM, since I think all the previous CWM zips won't install through 3...
Hopefully it's not an issue... but if it is, let us know and we'll figure something out.
Get rid of bootanimaton.zip which will revert you to the baked in boot animaton.
