Bugless Beast Froyo release!
That's the thing its not pre-installed on this one and market download doesn't work for me
Weird. Guess it installed from the market for me since it lists installed beside it under Downloads. Wiped data and cache before installing BB 2.2 and maps work fine.
BB FRF57 v.01
Ok hats off to Pete..
This one has the same speed as before with lin and quad, but the phone itself seems snappier. It's very solid, no reboots even on installation. Metamorph is now fixed and I've had no issues with the market. Chrome to phone still works fine.
Sheesh, everytime I think I can relax, something else comes out. Pete got this out sooner than I thought. I thought it would take another week. One thing I did do is the long benchmark on setcpu and got an insane 520. I never checked it with the last froyo build, but I used to get around 700 on 2.1 with 1.1 GHz OC.
Ok, give me some sic custom themes and I'm good to go for a while. I'm sure there will be updates and such, but dang, let my droid rest for a day or two, lol.
:cool:
Hawk
Running BB v0.1 + launcher Pro+.
Team Chaos's Black Ice for Froyo
ya i installed it and everything works perfectly, even the market. just gotta choose a kernel to install.
part of me feels that since froyo is near perfect, we are going to see more themes for it then actual custom roms. anybody feel the same way?
Yeah alot of themes rather than roms they all feel about the same once you get it right
Yeah, with the general speed of Froyo, people will be more concerned with creating a custom look rather than spending time to optimize and speed things up.
Also, to get flash to work, you'll need to use Astro or Root Explorer to delete the AdobeFlash apk from /system/app so you can reinstall it.
one thing that i can see some ballsy devs try to do is create the perfect overclocking rom and kernels to go with it. one that will let you set the max to +1.2 ghz and the min to like 1 ghz and still have low temps. is it possible, idk. does it seem like the only other thing they could do to this rom, to me that would be the only other thing aside from themes
Brett,
I was thinking the same thing. With the speed that's already here, themes will be the main thing for a while, but you can bet the kernals will be worked on to push the limits without having the heating issues. I flashed roberj13's blue energy theme and it loaded with no problem.
Sweet build Pete.. I've been lucky as I've had none of the issues as some of the others. I even downloaded the maps with no problems.
Hawk
Just downloaded it and will probably stick to it until Pete makes a BB ROM off the official release. I think BB > any other ROM.
What are some of the kernals people are using? Iinstalled this Rom but could only get 800mhz on SetCPU? Did I miss something?
For anyone out there that has yet to get the chance to switch over to Bugless Beast 0.1 and needs an awesome walk through that is simple check out the Droid Life post.
If anybody's still having issues installing maps you might want to try this. You will have to get copy of the maps.apk first. (My maps installed on their own, so i don't know if this works or not)
How I got maps to work!
Put the Maps.apk in you sdk/tools folder
For some reason, ADB won't work in Froyo under normal boot conditions, so we must reboot recovery to push busybox to /system/xbin
Code:
adb reboot recovery
Once in Clockwork, scroll down to the partitions menu using the d-pad or volume keys.
Plug your phone into your computer now. Open a terminal window and cd to your ADB tools directory.
On your phone, select "mount /system" - should be the first option.
Code:
adb push Maps.apk /system/app
adb shell chmod 755 /system/app/Maps.apk
unmount the System, Reboot and google map the nearest Starbuck I hope this helps
working 100%
__________________
Team CHAOS team member #2
New IRC come in and say hello!
Buy Me a Guinness!!
Follow Me @bgill55
Team CHAOS homepage
Can people that are running this post up their batter life experiences? I loved the speed of BB1.1 but I had to charge my phone twice a day. Same with cyanogen and I just loaded JRummy The Shizz but now my gallery is not working.
i've had this bbv0.1 installed for about 12 hours now and it was fully charged when i loaded it after setting up my screens/widgets i set it down went to sleep and its only at 90% so far so good
Foxy
