Bugless Beast Froyo release!
So I loaded BB how do I use / run the scripts? I downloaded Android Terminal Emulator and tried running -rmmp3 and got an access denied message. Any ideas / help would be appreciated.
type "su" first, without the " of course then it should pop up and ask for root access hit allow and then type hte scripts
does it seem like more apps are opening without you actually opening them? for example...BB v1.1 whenever i killed my apps i would have only as many as what i used since the last time i killed them(plus a few usually) now it seems there are many apps that are open that i never used.
Alright, I held up for a few days but ended back with BB. My vanilla Froyo started to act up and moving to BB fixed it.
bb froyo
ok so i know this is probably hidden deep within a thread some where but i cant find it. anyway, i have rom manager and i see the bb froyo on there but what else do i need to flash onto my phone for it so there are no problems i have seen so many things and i just cant decyper what is going on with it. sorry if i seem like a noob.
thanks
Mike, that is all I did... went to ROM manager and installed from there (I did wipe data and cache).
The very last version (from 6/10) did not have any WiFi issues for me - I never installed the version from a few days earlier.
Has anyone tired or is it possible to install the P3 kernels with BB 2.2 ROM from Rom Manager? I want to run my BB 2.2 at 1ghz.
I'm running the 1.25GHz P3 kernel. The phone restarted as soon as i tried to run it at full speed, but It was fine at 1.1, I've got it turned down to 900 now and it's running great.
So I am on BB V0.1 and I wanted to try other froyo roms, so I downloaded the Onyx froyo rom from Rom manager. I clicked wipe data and then the phone would restart.... but thats it. It would only restart and I still have BB V0.1 on my phone. Any thoughts?
In ROM manager reflash clockworkrecovery 2-3 times and try again.
v0.2 is available. http://bit.ly/9rAtqZ
Nothing overly exciting but has a few handy features
Changelog
*Version 0.2 (6/15/10)
-Fixed Apps2SD on Froyo! Most apps will now install to the sdcard automatically
-Updated Busybox to V1.16.1 (more commands)
-Fixed busybox wget command
-Readded automatic overclock to highest available slot
-Added full sysctl support
-Added Google DNS for a faster and safer online experience
-Removed google analytics from hosts for ROM Manager stats
-Made ADB Shell run as root by default (eliminates the need to type in su)
-Added Reboot Recovery option (hold power & vol up button)
-Added Reboot option (hold power & vol down button)
-Added Shutdown option (hold power & half pressed camera button)
-Added Clean shutdown/startup from Cyanogenmod
-Added custom wallpapers (thanks Prash, HTC, Google, etc.)
-Added MANY new tweaks for added performance and battery life
-Bypassed setup wizard to save time after a data & cache wipe
-Disabled Location Services by default (saves battery life)
-Wifi Issues should be fixed (wipe data & cache if they still occur)
thx downloading now time to check a2sd though the update of setcpu if you put it on the sd it broke the widget
amateur_user
