- Jun 6, 2010
- 73
- 0
- 0
Alright, perhaps I'm a bonehead.
I wanted to update my Nexus 7 to 4.1.2, but was blocked (according to the error message in CWM) because of my build.prop. That makes sense as I tweaked my density to 160 using ROM Toolbox in order to get the full-on tablet effect.
So, I downloaded a JRO03D build.prop from this thread: stock build.prop needed - Page 2 - xda-developers. The actual file is here: http://core.routed.com/build.prop . I saved that file in my Download folder as "stock-build.prop."
Using Root Explorer, I copied stock-build.prop into /system, renamed my tweaked build.prop to mod-build.prop, renamed stock-build.prop to build.prop and rebooted.
I now get the white Google text logo with the unlocked icon, and the screen goes to black. If I hold the power button for 10-ish seconds, the white Google text logo and unlock icon come back and then back to black screen.
Maybe the file permissions on stock-build.prop weren't sufficient? I know I didn't check.
How do I get back up and running?
Thanks
Jack
Thanks
Jack
