Building your own ROM
So I decided that I wanted to try my hand at the next step up in making a custom ROM, and that is going from modifying already built zip files to compiling the source code straight on my computer.
I followed the steps in post 3 of this thread, but I didn't get a zip file in out/target/product/thunderc I only got an assortment of files that look like they are my ROM...but not zipped.
I've attached a screenshot to illustrate.
Did you have any errors after make bacon?
Not that I know of, but I should really pay better attention to the screen haha. Do the errors all get listed after make bacon is completely finished, or do they Just pop up as make bacon is running? Just trying to get a handle on if I have to watch the screen the whole time lol
I should also include this doesn't have any modifications yet. I was simply compiling after finishing syncing the repo to see if it all worked.
EDIT: Just ran it again and up I got 3 errors. Or one. I'm not sure.
Here's the end of my make bacon.
Code:
target Strip: libstagefrighthw (out/target/product/thunderc/obj/lib/libstagefrighthw.so)
target Strip: libcamera_client (out/target/product/thunderc/obj/lib/libcamera_client.so)
target Strip: bootanimation (out/target/product/thunderc/obj/EXECUTABLES/bootanimation_intermediates/bootanimation)
target SharedLib: libcamera (out/target/product/thunderc/obj/SHARED_LIBRARIES/libcamera_intermediates/LINKED/libcamera.so)
target Strip: screenshot (out/target/product/thunderc/obj/EXECUTABLES/screenshot_intermediates/screenshot)
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
3 errors
target Strip: libsurfaceflinger (out/target/product/thunderc/obj/lib/libsurfaceflinger.so)
make: *** [out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes-full-debug.jar] Error 41
make: *** Waiting for unfinished jobs....
We can't see your errors, there are up further. Copy and paste the whole log on pastebin.com and post the link here.
I'm betting it's the omap libraries. I just got finished building after syncing with IHO+CM, and the build would error out with undefined omap classes. I did a quick google search, and found this post in an asian language:
Richard's Blog - ITeye
It shows you need to add the following line to /build/core/pathmap.mk
Code:
project build/
diff --git a/core/pathmap.mk b/core/pathmap.mk
index 6cd3b8f..68e61f9 100644
--- a/core/pathmap.mk
+++ b/core/pathmap.mk
@@ -89,6 +89,7 @@ FRAMEWORKS_BASE_SUBDIRS := \
 	    vpn \
 	    keystore \
 	    voip \
+	    omapmmlib \
(you add the line that starts with +, removing the + of course ;) )
This seems to fix the build errors, testing on my phone now.
Where is the log file? lol I honestly just copied and pasted from the terminal window...but I will try JerryScript's possible fix to see if that is what it is. If it is, then woohoo! I built my first android system lol
When you build, and there are errors, the error output will have a pointer icon beneath the character that begins the error, example:
Code:
    int Stuff = "Some text";
This example is showing there is an error begining at the quotation mark (you can't set an integer to a string)
These errors are sometimes high up in the output, since the build system is sometimes working on multiple packages simultaneously. When your build errors out, scroll up to the first instance of a line such as I've shown above. There you will find the clues as to what the problem is. ;)
Its not necessarily building an android system, blarf did that for us. You are just compiling from his source. There is still a sense of satisfaction when you finally got your own. Zip file you created
Well yes, creating my own zip. I should say that instead, but it's a big step up from just modifying an existing zip
Okay, just ran it again lol
Here's the log: first build - Pastebin.com
However I believe it is the omap library's JerryScript is talking about, as after scrolling through all that, I found two error references to omap library.
the first and second
Code:
frameworks/base/core/java/android/widget/VideoView.java:46: package com.ti.omap.omap_mm_library does not exist
import com.ti.omap.omap_mm_library.OmapMMLibrary;
frameworks/base/core/java/android/widget/VideoView.java:62: cannot find symbol
symbol  : class OmapMMLibrary
    private OmapMMLibrary mOmapMMHandle = null;
third error
Code:
frameworks/base/core/java/android/widget/VideoView.java:196: cannot find symbol
            mOmapMMHandle = new OmapMMLibrary();
I'll try that fix now and see if it works then
EDIT: Yep that fixed it. It went through and compiled everything then made my zip, I flashed it to my phone and it worked! Obviously it's got some unnecessary stuff on it since it's pure IHO/CM7.1 but now is the time to tinker with it and start adding and deleting stuff :D
Glad you got it working! Welcome to the addiction! ;)
More like obsession haha
Reminds me of this animated gif my programming professor put up on the first day of class. It depicts a stick figure sitting at a computer typing away, and then his keystrokes become furious and he smashes his hands on the keyboard and then his hands start to disappear (it was kinda graphic for a stick figure lol)
Code:
project build/
         vpn \
         keystore \
         voip \
+        omapmmlib \
Does this fix allow this surfaceflinger commit or do we still need to revert? https://github.com/CyanogenMod/andr...dbd3e5191f7336e47736ef04#commitcomment-698298
To fix the sound problem in movie recording was a permission issue, grab this file to fix it: https://github.com/BobZhome/android_device_lge_thunderc/raw/gingerbread/files/ueventd.thunderc.rc
Also, you can grab the new kernel here: Kernel_v3.3.zip
And to added custom carrier label to your builds, grab these two cherry-picks:
Code:
git fetch http://review.cyanogenmod.com/p/CyanogenMod/android_frameworks_base refs/changes/14/7314/2 && git cherry-pick FETCH_HEAD
git fetch http://review.cyanogenmod.com/p/CyanogenMod/android_packages_apps_CMParts refs/changes/13/7313/3 && git cherry-pick FETCH_HEAD
Are you referring to this problem? A wrong file permission would consistently, always disable the sound. But this problem happens inconsistently and triggered by another reason IMHO. Thanks, I will check anyway.
By the way, could you please briefly tell what is different in v3.3 kernel?
sevogas
