Building your own ROM
I've also seen that it "snaps" two points together when they're near, instead of smoothly crossing them when this software fix was applied on a different phone.
There were a bunch of updates to CM recently, mostly on 1019, you'll need to merge the commits or manually pull them into your local repo in order to build. ;)
Reactions: bigsupersquid
Yeah, I'm getting build errors because of this.
What is easier - to merge commits, or manually pull?
Could you please give an example of how you do this?
The problem is you need to control your environment. You need to setup your own github.
When CM posts updates/fix's, so times the updates go hand in hand in two different sections.
Example: Yesterday there was an update for CMParts that required variables defined in the frameworks, so you probably got an error like this: make: *** [out/target/common/obj/APPS/CMParts_intermediates/classes-full-debug.jar] Error 41
Reactions: rb64
Which leads me to Tip of the week:
You have forked and setup an upstream for lets say: inferiorhumanorgans/android_frameworks_base
You don't need to start over to change upstream, just open up ~/android_frameworks_base/.git/config
and remove all the [remote "upstream"] info.
Then add a new upstream :-*
I've been wondering if we took what I.H.O put together and applied it to the android source code (which is up and running now) would it work? I've been wondering about this for two reasons one we never got a fully stock 2.3 and in my mind we would get android icecream alot faster then waiting on cyanogen
Yes, you can modify the appropriate files to build vanilla aosp, pm'd you.
IceCreamSandwich is another story. There are significant changes to jit, and several system level functions have been added/changed/removed. It will definitely take some work to get it going on the OV. If the right people get involved, we may beat CM to the punch, but only due to the number of phones they support now, that's the only thing slowing them down. ;)
Those computer specs for building ics are pretty crazy compared to what I got.
16GB of RAM? I won't believe it until I try myself. I have built complete Linux systems (GNU compilers, glibc, kernel included) from ground up using computers with less than 4GB RAM. Unlike gigabytes of files in a Linux system, Android OS will eventually fit in a phone's tiny flash memory. What is so special about ICS?
I've been sitting here in awe thinking about this. There's no way that's probably just his machine.
I can build Gingerbread in less than an hour on a 2.7ghz oc to 3.2 dual-core system with virtually no free memory available:
Code:
jerry@ubuntu:~$ free
               total           used           free      shared   buffers      cached
Mem:       1796276    1781380      14896          0     562192     654964
-/+ buffers/cache:     564224    1232052
Swap:       262136          0     262136
I'm sure I'll need to add some RAM, but I think 8gigs should be plenty! LOL
I think the person who said that was trying to brag a little as in "hey look at the rig I got". I've built IHO on 1 GB of RAM before (with virtual swap), so even if ICS is twice as big, 2 GB RAM should work. It might be slower though, as in hours instead of minutes.
Code:
I feel inadequate standing next to you now. LOL
ive got a problem, ive tried everything but cant get this to work.
i cant keep redownloading the repo as ive already used all my bandwidth on mine and my gf's phones.
save me
Code:
richard@androiddevelopment:~/android/system$ source build/envsetup.sh
including device/lge/thunderc/vendorsetup.sh
including vendor/cyanogen/vendorsetup.sh
richard@androiddevelopment:~/android/system$ lunch
You're building on Linux
Lunch menu... pick a combo:
     1. full-eng
     2. full_x86-eng
     3. simulator
     4. cyanogen_thunderc_VM670-eng
     5. cyanogen_thunderc_LS670-eng
     6. cyanogen_thunderc_MS690-eng
     7. cyanogen_thunderc_US670-eng
     8. cyanogen_thunderc_VS660-eng
Which would you like? [full-eng] 4
vendor/cyanogen/products/AndroidProducts.mk:1: *** missing separator.  Stop.
** Don't have a product spec for: 'cyanogen_thunderc_VM670'
** Do you have the right repo manifest?
richard@androiddevelopment:~/android/system$ make -j10 bacon
that fixed the problem thanks, now i got more problems :/
Code:
Breakfast menu... pick a combo:
     1. full-eng
     2. full_x86-eng
     3. simulator
... and don't forget the bacon!
vendor/cyanogen/products/common_full.mk:9: frameworks/base/data/sounds/AllAudio.mk: No such file or directory
make: *** No rule to make target `frameworks/base/data/sounds/AllAudio.mk'.  Stop.
richard@androiddevelopment:~/android/system$ make j-10 bacon
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=2.3.7
TARGET_PRODUCT=full
TARGET_BUILD_VARIANT=eng
TARGET_SIMULATOR=
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a
HOST_ARCH=x86
HOST_OS=linux
HOST_BUILD_TYPE=release
BUILD_ID=GINGERBREAD
external/webkit/Android.mk:83: external/webkit/bison_check.mk: No such file or directory
external/webkit/Android.mk:223: external/webkit/WebKit/Android.mk: No such file or directory
external/webkit/Android.mk:397: external/webkit/WebKit/android/wds/client/Android.mk: No such file or directory
external/webkit/Android.mk:400: external/webkit/WebKit/android/benchmark/Android.mk: No such file or directory
external/webkit/Android.mk:403: external/webkit/WebKitTools/android/webkitmerge/Android.mk: No such file or directory
find: `graphics/java': No such file or directory
find: `location/java': No such file or directory
find: `media/java': No such file or directory
find: `opengl/java': No such file or directory
find: `sax/java': No such file or directory
find: `telephony/java': No such file or directory
find: `wifi/java': No such file or directory
find: `vpn/java': No such file or directory
find: `keystore/java': No such file or directory
find: `voip/java': No such file or directory
find: `test-runner/src': No such file or directory
find: `frameworks/base/docs/html': No such file or directory
find: `out/target/common/docs/gen': No such file or directory
make: *** No rule to make target `external/webkit/WebKitTools/android/webkitmerge/Android.mk'.  Stop.
That's the issue, when Blarf pulled in the recent commits to CM, it reverted my pull request that added this line to the top of the vendor/cyanogen/products/AndroidProducts.mk file:
Code:
PRODUCT_MAKEFILES := \
TOOLS
