camera glass protection
Just arrived Caseology camera protectors, So took few photos in the dark with flash with the WSD that are still on, So my question is theses Caseology camera protectors not gonna show the bug that WSD shows with flash on.
It shouldn't. The science being that because the WSD is completely clear (as are some others, even with the laser and flash cutouts), it is pulling the flash along the glass, similar to how fiber optics work with bending light from one place to another. Also considering the adhesive is applied to the entire portion of the glass on the WSD, that could be causing more reflection of the flash, and pulling it toward the lens. The Caseology and Spigen bot have black adhesive only around the necessary areas, so it is less likely to pull or reflect the flash into the lenses. Not saying that is a concrete explanation, but it sounds like that's the case so far.
Ok will put later.
I'm still waiting on mine. Delivery notification now says between 7pm and 9pm tonight. If I don't get them by tomorrow, I am just going to order the Spigen ones. Might even see if I can just order them directly from Spigen or Caseology, because Amazon delivery is not living up to the Prime price.
Before WSD with flash
And now Caseology glass protector with flash.
Definitely big difference.
Pictures of the cameras modules wearing these covers please?
I'll have to take them tomorrow, but I also put the dbrand skin back onto the glass. I will take a picture when the skin is off. I'm going to change skins tomorrow anyway.
Here is the camera with the caseology screen protector on it. I have the Mystic Black Note20 Ultra, so the black glass is fine, but I'm also using a skin. So, I'll skin the glass too.
Thanks. Clean look. And I guess the blackening around the lens probably should help with light hitting the cover from angles causing distortion... just too back in the case of Mystic White that it covers a nice looking silver trim. But functionality if more important.
You could try to find a silver skin to put over it. Im using a skin over the camera glass. You wouldn't even know the protector is there.
cpoole89
