Can you slow charge S7 Edge on a fast charge wireless pad?
A
AC Question
Hi All, I was wondering whether or not you can slow charge the S7 Edge on the fast charge pad. I've heard it is good to slow charge every so often. I've seen in the settings you can disable quick charge but does this work with the charging pad also?
Thanks,
Steve
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It's not "good" or "bad" to "slow charge". Fast charge seldom gets anywhere near 1C (IOW, for a 3,000 mAh battery, that would be a 3,000 Ma, or 3 Amp, charge), so it makes no difference whether you charge it at 800mA, 1,800mA or 2,800mA - it's still under 1C.
Can your particular charging pad change charge rate? Look at the book that came with it.
sdaservices2000
