Can't Unroot
Root went through successfully again... what would be the easiest way of finding out if I have those permissions now? Try to flash a rom?
While in hboot it should have said s-off. If it says that and you have cwr installed you should be able to flash a rom.
Flashed CWR?... I'm still showing the same stupid screen.
Go to install the custom rom off the SD and then I select backup current rom and wipe data.
Phone goes black then starts up with the HTC logo and then I'm back in the bootloader where it shows the
***Security Warning***
MECHA XD SHIP S-ON
and the rest of the boot instructions.
What is CWR? I'm still showing the same stupid screen.
MECHA XD SHIP S-ON
CWR is Clockwork Recovery that is what you use to load custom roms with.
Try powering down your phone after it is off, hit volume down and power. Tell me what the first line says.
After the phone is shut off hit the volume down and power until you are in the hboot menu.
The first line should say MECHA XD ENG S-OFF.
The bootloader security is turned off during this procedure.
Quote:
The terminal window must display the following checksum: 6991368ee2deaf182048a3ed9d3c0fcb
$ ./adb shell dd if=/data/local/hbooteng.nb0 of=/dev/block/mmcblk0p18
$ ./adb reboot bootloader
Still didn't work held it for 40+ seconds. However it did start up insanely fast after I released the power button and then held it back down while holding the volume down button. It showed the thunderbolt loading and then it skipped the clouds after where it usually lags and went straight to the unlock.
The tutorial says:
$ ./adb shell dd if=/data/local/misc.img of=/dev/block/mmcblk0p17
Plug your phone into your computer, open adb in a terminal and type
First line should read
MECHA XD ENG S-OFF
I removed the P05IMG file if that does anything.
-bash: ./adb: No such file or directory
You will need to get into adb the same way you did in the tutorial. After you have a connection to your phone you will want to enter the command I gave you earlier.
That's fine you removed the PG05IMG, it is not needed now anyway.
I can't get into adb the same as the tutorial. it keeps giving me the -bash: cs: command not found
You will need to find out where adb went on your system and get into it, after you have a connection with your phone run the rebooot bootloader command and see if you have s-off. If you don't have s-off then something went wrong with your root process and you will not be able to flash roms.
I got into the bootloader and restarted it via the computer. S is still on. I'll go back through the root one more time just like I have been and see if that does anything.
Make sure you are checking your md5sums very closely. If they are not correct then something is going wrong.
When I'm done with this final attempt I'll post up the whole terminal log so you can see that there were no mistakes.
Got everything to work. 3rd time must be a charm.
Also if I flash to a new rom and backup my old rom. Will all of my apps and widgets be in the same exact place and layout as I had it set before?
Glad you got everything running properly.
Whenever you flash a rom you will want to wipe your data and cache partitions so you will lose all data and apps. A lot of people purchase Titanium Backup from the Market to do quicker set ups after a rom flash.
paradigm76
