Car charging
ens04
206
13
I dont know how many of you guys use car chargers but I am really interested in buying a car charger. I would really like to know if car chargers are a really good idea. By that, I mean, does charging your phone in your car drain your car's battery alot? Or does it use a little bit of ur car's battery, so is it safe?
Sent from my LG-LS670 using Tapatalk
shortyjacobs
443
89
You will never kill a car battery charging a phone. Not unless you never start your car. There are hundreds of watt-hours in a car battery, and your phone's battery takes like 7 watt hours total. It would take a LOT of charges, empty to full, of your phone to make a dent in your car battery. And as soon as you start the car, it's back to fully charged.
Reactions: ens04
the_mastermind
52
If you plan to buy one i sugguest ebay where you can get then for probably less than half the price in most stores. The build quality isnt as great but it works just as good.
chilinski
3
If you go to Wal-Mart you'll find one for about $6 that's sold at the cash registers (you know, by the candy bars and stuff). It has two USB ends on it...one that fits the Optimus S and one for other devices that use the slightly larger USB connector. The other end is a standard USB plug that goes into the cigarette lighter plug. Note that you CANNOT use this cable as a data cable from your computer; it can only be used to charge.
basketthis
1,470
473
Bought one the day I bought the phone. My car battery is fine. ;)
But seriously, you wont have any issues. I picked mine up locally but if you have patience to wait for it to come in the mail, listen to what people are saying about ordering one online.
Androidcentral has a very nice store that they have setup for us. http://store.androidcentral.com/and...rgers&utm_content=menu&utm_campaign=community and all you need is a micro-usb car charger. This link takes you to the charger section. :)
choll
