Case Recommendation can be used with the Samsung Wireless Charging battery cover.
jummybui
49
Hello All,
I am trying to find a case that will work with the Samsung wireless Charging battery Cover. It is thicker than the standard battery cover.
I have the following cases now and none of them work.
Spigen Neo Hybrid Case
Caseology TPU Case
Ringke Slim Case
Ghostek Bull Slim Armor
Please help me :)
Nah, there is nothing out there right now case-wise to use with the wireless back cover. I ended up getting one of those aluminum bumper frames you can get on Ebay or Amazon for $7-$8 and it's not bad. Fits very nicely with the wireless back cover.
Granted you won't get total protection but it looks nice.
Thanks! Ill check out the bumper frame.
Get the tech21 case and warm it up with a hair dryer till its quite supple....then it will go on your phone!
Thanks for the idea. Not sure if i want to spend $40 on a case just to do that. I may give it a try on the TPU Case I have
cbum63
