Casemate case - easy to remove? Wireless charge work?
NoahForeman
140
VZW is holding one for me to grab later today. Is the case easy to take on and off? Has anyone tried wireless charging in it?
Thanks!
Posted via the Android Central App on my Droid Turbo.
Thanks!
I've used cased on my Nexus 5 that were think and wireless charging still worked. Although this device is different, I don't think there will be any difference with charging capabilities since Casemate cases generally are not too bulky.
In any event, let us know how it goes and what you think of the case.
Got it tonight and like it so far. Already has micro scratches, but any clear case is going to get those, lol.
It only adds like 2.5mm to the phone. The nylon is right up against the back price. Both the bumper and the backing fit snug but are only slightly difficult to remove.
Seems like a keeper, but still a bit much at $35.
Thanks!
Wireless charging works fine with the casemate case.
I am noticing that the Vol.- is a little harder to press than the Vol.+. Anyone else find this to be true as well?
Yes I have the same issue. It seems that the volume on the case is a little lower than the phone so when you got the bottom of the down it is hitting phone frame. I work through this by just hitting a little higher on the button. Pain but it works.
