Cases, cases and more cases!!
Is anyone using any clear Magsafe cases, and has tested the SPen with a Magsafe accessory on it?
Sent from my SM-S918U1 using AC Forums mobile app
I did my standard test, but without being attached to another MagSafe accessory. No interference just with the case (Ringke Fusion magnetic)
Sent from my SM-S918W using Tapatalk
Yeah, I'm trying to find consistent reviews with an accessory attached to see how useful it will be. Namely either a popsocket or battery pack. I can't think of another use case where I'd use the SPen and have something attached to it.
If you ever have a chance to test with any accessory attached, I'd appreciate any follow-up. This Ringke fusion Magnetic is one I am interested in. I have the regular Ringke Fusion currently
I don't have a MagSafe pop-socket or power bank, but what I can do is that next time I'm in my car (in about 1-2 hours), I will mount it and do the same scribbling test while it charges.
It's importan to get a case that protects every single lens in an individual hole each camera lens or the big hole around all the camera lenses???
Thanks so much!!
I'm afraid I have bad news. As you can see, there are big gaps when the phone is actively charging. I changed the colour to blue and did a second take in the gaps to test if it was truly a "dead" zone and it looks like it was for the most part.
Thanks for the testing. I was kinda on the fence with this MagSafe stuff, I think I will pass.
Yes, thank you so much for testing! This is what I was afraid of. These other reviewers aren't properly testing for this. Looks like I'll have to pass on magsafe until samsung can make the proper adjustments for it.
Luckily, I don't ever see myself in the scenario where I'm using a MagSafe accessory and the S-pen at the same time, so I will continue to enjoy the one thing that I got it for: straightforward wireless charging for myself and my iPhone-using wife :)
Yeah, the 2 reasons I'd want the MagSafe is so that I could have at least either a PopSocket for the grip or a battery pack in case I'll be away from a charger for an extended time. I also don't like the permanent placement of the OG PopSockets, or the bulk of kickstands.
I suspect that any wireless charger would probably intterfere with the S-Pen. Wireless charging uses induction and the S-Pen uses induction.
As any engineer will tell you H+H=:(
I think I'm finally going to order a case tonight or tomorrow though and plan to get a PopSocket too, so I will report back with my findings.
Exactly. I also think it would be awkward using the phone and spen with the battery pack on the phone. This is a non issue for me
Sent from my SM-X800 using Tapatalk
Different strokes for different folks.
Absolutely. I said I think it would be weird. Might be fine for others, but in the discussion we are having the spen will have issues if you do.
So I'm glad I have no interest in using the spen with the battery or wallet attached. Bonus for me
I stuck a magnet to back of phone and spen was non responsive when over the magnet. I think any of the magsafe stuff will cause interference of the spen.
I'm fine with that as I more then likely won't be using the spen when I have the battery or wallet attached. I'm going to pass on the ring since that I can see myself using the spen with.
siratguidance56
