installed last night, battery actually might be a little worse for me (was running virtuous custom #2) but will give it a full week for testing. Also i have the virtuous rom 3.1
sorry for asking a dumb question but what is a kernel and what does it do. also i just rooted today so how would i install this if i wanted to?
i tried to clear Davilk cache on my phone for this kernel, but it wont. says somethin bout not mounting the sd card?
E:Can't mount /dev/block/mmcblk1p2
(file exists)
but then i hit yes, and says dalvik cache wiped
It's a benign error. Generally means an improper formatting/setup of your sd card. You don't have have sd-ext partition setup for apps2sd. It tries to mount it, but cannot since the file doesn't exit (even though it says it does). You can fix it by formatting your sd card with RA recovery with the default values of 512mb of sd-ext (the reported minimum is 128mb), 32mb of swap, and the rest as FAT32. RA recovery can format your SD card; just flash it in ROM Manager under the Alternate Recovery option, reboot into recovery, format your sd card with the guidelines I gave, then flash Clockwork back through ROM Manager if that's the one you prefer. Supposedly Clockwork 2.5.1.1 has this option, but I've haven't tested it so feel free if you want, and let me know how it goes.
But again, it's benign, so you don't HAVE to fix it especially since it doesn't affect clearing the dalvik cache. Personally, I do since I don't like errors, benign or not.
Well I flashed this kernel 2 days ago and I do not see any improvement in battery life or charging time. In fact both still seem worse. Now it may be my fault due to CPU settings but I was expecting more from this.
I downloaded SetCPU and formatted everything to smartass. I did not overclock as I don't need to. Should I be setting my cpu settings to something different to increase battery life. I though this kernel was supposed to help battery life because of smartass.
Hi Rugyua9.
I decided to try the setCPU to see what was going on with this kernel. I noticed that the default governer was set to smartass but when I looked at the different profiles (ie: Performance, normal, screen off, powersave, extreme powersave)they weren't set to smartass.
I then had a problem with my wifi. When I press the power button to put my phone into sleep mode then turned it back on my wifi connection was turned off. Then I realized that under each profile were the services that each controlled. So I set them all to leave alone instead of enable. That fixed that problem but I am not seeing any benefit from this kernel.
Thats why I said I may be the problem not the kernel because I went in and changed the settings. So the question is do I just delete the SetCPU and let the kernel do its thing or just tweak the cpu settings.
