- Dec 4, 2012
- 35,752
- 833
- 113
If it was a C-C he wouldn't have this problem.
That isn't necessarily true. If you used a C-C cable from the OnePLus series, that wouldn't get you fast charging either.
Well sounds like I'll just grab a new cable on Amazon and hope that solves the issue. I have tried at least 5 other cables around the house and they all work fine.
To clear up any confusion the cable that does not work is a regular USB cable into a 5 USB port wall outlet. If I go ahead and plug any other USB to USB cable in there it works fine, and again, this cable with USB adapter works fine for any other device I try it on, so I was confused as to why it would work w/ the new P2. But I guess knowing is not important, I'll just order a new cable and I figure it should work, as every other cable I have around does, they just aren't long enough.
Also, I am aware that the charge rates may differ not using correct chargers and cables, this does not matter to me overnight where this charger and cable is, but thanks.
