Sup es. Long 2 days. Flashing M5 as we speak!
Nothing like a motley ROM flashing on a Sunday morning.
By the way, I suggest flashing the 3-17 Gapps rather than the 4-22 version. That way Play Store restore works and your other Google account settings will restore as well.
Sent using Tapatalk 2
Ironically, I just saw your post about that after it was said and done lol. I was in the midst of TiBu restore when I posted this.
I wonder why the GAPPS no longer feature restore, restore of WiFi/networks, etc.
It probably wasn't intentional. According to the RW thread, a change to the filename of one of the Google apps causes restore to break.
Until they fix it, the workaround is to flash the 3-17 Gapps and update the apps in the Play Store after you set everything up.
Looks awesome, the only problem i see is my big fingers/thumb would never hit only one button. I could see that problem driving me nuts in a matter of minutes! Love the idea though, if the icons were a bit bigger i would definitely consider this when CM9 is finished.
Looks like it would be great on a Galaxy Note! Sounds like the text may be a tad small for me to use everyday.
On a related note, just loaded up the latest CM9 nightly in a Boot Manager slot. It's been a while since I've tried CM9 and it looks like it could be a daily driver at this point. Still a few things that are unfinished (like Theme Manager) but all the parts I care about are there and seem to be working fine.
How far along is trebuchet? Cid in the boot anim yet?
Didn't spend too much time using Trebuchet as I loaded up Nova Prime after flashing. Can confirm that Cid has arrived and is featured in a snazzy new boot animation.
Oh yeah? Uh oh...may have to nandroid and flash.
Go for it. I last tried CM9 about a month or two ago and it was much more of a work in progress. It still is, but the missing features I've found so far are now ones I use (theme chooser and fancy lockscreen options).
It's quick and smooth. It reminds me of why I stayed with CM7 on my ThunderBolt after trying practically every ROM for that device.
So it has lock screen options? Excellent!
