Check for ICS manually & its there
all i get is "check for update is not available at this time, try again later"....WTH does that mean?
I had that error before the last update and had to do a factory reset to get rid of it. No idea what caused it.
Sent from my DROID RAZR MAXX using Tapatalk 2
Reactions: JSQ
I'm in Baltimore for the weekend, just checked and downloading as I speak.
Sent from my DROID RAZR using Android Central Forums
No notification or email ever sent, just kept checking manually
Try #15... Can not validate download STILL..... ahhhhhhhhg... So close yet so damn far away
Up at 6:30 AM in Connecticut and checked for the update and it was there. Downloaded no problem. My 2nd device is on its way unfortunately because the one I have now is not acting right. Sometimes it will not allow audible alerts to work on the device such as alerts for the different emails, text messages, key presses, etc. Did a hard reset once already and it seemed to fix the problem for a little while but it started back up again.
VTX1800N1
appreciate it. that worked. its downloading now!!!! here comes my sammich!!!
Thanks
Got it, looks great! Love the new keyboard and app drawer flow.
Sent from my DROID RAZR using Tapatalk 2
No progress.....?
Boston area. Multiple tries.
WiFi on = "checking for available update. please wait....." 10, 20, 30, 40 minutes, no change
Wifi off = "check for updates is not available at this time"
Thoughts?
I am still getting "cannot validate". Tried on Wi-Fi and 4g with the same results. Any ideas/suggestions?
Sorry, it says "can not be properly validated" anyone else getting this?
Sounds like the server is jammed, probably not your phone in your case or at least I hope so.
I was able to get it downloaded and installed shortly after midnight CST. For all of you doing this, know that it will take a few minutes even after ICS boots for you to be able to do a few things and you will have to delete and reconnect your exchange accounts if you have them so make sure you check what your settings are before you try to upgrade and have them ready. I say that because I realize some of you do not manage your work network and may not be completely savvy on the way that works.
If I can be of any help to anyone, shoot me a message and I'll do what I can.
dooleysdickulove
