- Feb 2, 2011
- 37
- 0
- 0
If you guys are in the market for another USB-C charger and cable then I would recommend this combo by the company Choetech. The charger supports the quick charge for USB - C so my Nexus 6p charges very quick and the cable is pretty long as well to give wiggle room. The cable doesn't feel cheap either. I've been using both for the past week and haven't had any issues and actually boxed up the charger that comes with the Nexus 6p using the Choetech one exclusively now. I sadly can't leave links as my post count isn't high enough yet. I just got active on here but if you search Choetech USB c cable and USB c charger you will see the results. Try them if you are in the need of another USB c cable and charger.
