- Jun 3, 2010
- 80
- 0
- 0
Bingo. Just tested it on 10 videos and it worked flawlessly! Huge thanks!
Lucky you..i tried it and it didnt do a thing for me
@Alextro, old videos recorded with 2.1 are choppy, record new videos on 2.2 with flikr adjusted to 60, it works, I have tested it. Now I am working on the battery life, which is worse than 2.1.
So the 60Hz thing is a recording option, not a playback option. Others are reporting than when the video are taken off the phone, they play smoothly on a PC or in YouTube. I tried adjusting this setting and it does not resolve my choppy playback problem. Playing the file a second time makes it a little better, but it is still crap! This really needs to get fixed. There is no excuse for a flagship product to have this kind of major bug! Takes me back to my Palm PRE days... NNNNOOOOOOOOOOOO!
Does anyone know if it's due to the class 2 8gb memory card we have? since it records at 2mbps and the HD video is just under 4mbps?
Maybe if we upgrade to class 4 cards, the 720p playback will be much smoother ?
The issue has nothing to do with the SD card. It's 100% software related and probably something stupid that they overlooked. 720P videos worked perfectly fine before the update.
I found a fix!!!! Lol this might sound obivous but a hard reset fixed the problem for me....my browser was fing up and i couldnt click links and force closeing...so i did a hard reset...and presto i took a 720 p vid and it played back flawlessly...i took 4 vids and tested it...ill also test vids tmr...im sure htc still needs to update this...but try a hard reset if this is important to you..it was to me..im very glad i did the reset!
