***FIX***
Hey all. Here's the simple fix for this...but it will cost you. And, I don't know why; I just know it "didn't in 2.1 but does in 2.2".
It is your microSD cards speed, or "class". The EVO comes with a 8gb Class 2 card. This seems to come up short in 2.2 for some reason. You will have to spring for a new card. Get at least a Class 6. I've personally "fixed" six EVOs and it works every time. Simply get your preferred card size (8gb, 16gb, etc) in a Class 6 or better speed rating and the video will record and playback smooth as butter. The "class" rating is clearly marked on the packages of cards. Look for it. The "class" rating is simply the card's ability to move (read/write) data. The chop you're experiencing is the card read/write delay. A class 2 card is a little shy of the data rate the Evo moves 720p video data. I would recommend before you install the new card to: Plug the phone into your PC, mount the SD card as a drive, & copy the entire card to a folder on your desktop. Then swap the new card in. The immediately copy/paste the entire contents of the folder on your PC right back onto the new blank card. You may need to format the card first. Reboot the Evo, and you will be set. NOTE: This fix is absolute and will end your video chop issues! (I'm sick of seeing so many posts and replys on this with folks stumbling in the dark. Spend the $25 and just get it fixed!) P.S. Try it, because if it doesn't work, just format the new card, put your old one back in, and return the new card. See...what can you lose, except your video chop...
