COBALT theme for AOKP M5
Thanks, I left a vote, very highly satisfied!
The dialers look good but atm nothing I would want to change the dialer I have now for. Im sure that will change in a week :P hah.
Reactions: davey11
what Calander widget is that? weather/clock? those are great!
The calendar is simple calendar widget with the similar theme (built in) and the clock is from beautiful Widgets with the suko ics skin. I got the layout idea from someone in the gnex screenshots thread
Reactions: darb85
Reactions: darb85
Depends on whether you mind more clutter. I personally like the first.
Also, the calendar widget has an option to adjust the transparency. Not sure if that is your thing but since you have a dark background right now with white calendar text a completely blank background for it may look good as well. Just an observation.
ok, quick question, I have the Simple calander widget up, but how do I change the settings?
Tap somewhere on the right hand side of the calendar. It should open up the settings panel for it.
gbTopaz
