Confirm Group Texting on Galaxy S4
Has your lab team tried this proposed solution for the Samsung ATT Galaxy 3S and 4S?
"Do not use the att messages app do not install updates or it will interfere with the stock phone messages app. uninstall the updates and disabke jf u already have. then, download the att visual voicemail app from the google play store."
TIA
What are you using to do this? I have the I337m Samsung galaxy S4. There is no options to enable group SMS... I am from Canada on Rogers and need group texting.
Here is a group message pic showing it works. It works on both stock and I am using go sms.
For taking a screenshot you need to go into settings and make sure your motions are set to use palm swipe for screenshot. My screen protector is thicker so it's harder so I usually hold down the power and home key at the same time instead
Sent from my SAMSUNG-SGH-I337 using Android Central Forums
How were you able to do this! I have the same Galaxy S4. There is no "allow group sms" option for me. I am using the stock messaging app. I am in Canada on Rogers
Hmm, I'm in Canada on Koodo and do have these options. They are in the messaging app settings. From the main screen (where all the conversations are) go into settings and scroll down to the MMS options, send a single message to multiple recipients.
I don't get why this won't work. This option is big for me for school and the fact all my friends and I use it. I have the MMS group messaging checked off but when I send a message to a group it turns into MMS. When they respond it is individual responses. I have read that the sim card could be the issue not supporting it? The sim I used was one I found laying around in a drawer probably from a year ago at least. Imessage was turned off prior and all that stuff. Very frustrating
kctraci1
