Cyanogen is playing tonight! :)
Has anyone tried the aluminum wireless KB yet? It should work - but there's a lot of wiggle room between should work and does work ;)
Once 4g is up and running I'm switching over from a rooted stock ROM.
I am going nuts! Cyanogen needs to kill this voicemail bug! I went as far as going back to a nandroid, wiping, reflashing, etc. I got it to stay off by skipping the initial setup, changing voicemail # to my # but it came back on reboot.
Bagger:
It is considered in the experimental category still...
I suspect these things will become less prevalent in the future :)
I feel ya, man. Little bugs abound.
I was having issues with my wifi disconnecting randomly (usually after ~30min), and some apps not seeing the wifi connection at all. I have terrible signal at home so without wifi most of the apps don't work (weather, browser, listen). The camera would also decide a few hours after flashing that it couldn't connect anymore. I nandroided back to Evo-NonSense for now.
[Cool story bro] point being for people reading this considering flashing- this is definitely still alpha/pre-beta material. Looking really promising, but still early. I wouldn't expect to be able to use this as a daily-driver juuuuust yet. That said, I'll probably still flash tomorrow's nightly just to see whats cookin :D
Delete the VM shortcut and re-add it from your programs drawer. That should fix the VM notification according to the thread at XDA.
Has anyone flashed the second nightly build of 7-20? I'm about to now. Wondering if anyone has noticed changes?
I flashed the second nightly, an hour ago. I noticed the roaming signal is gone. other then that I haven't noticed any different.
Did you have to re-flash the gapps? I noticed when I booted it back up it looked as if they were on there and I don't need to flash them.
So far, as hard as it might have been to do, it seems faster than the first nightly build. Maybe I'm just tired and it seems really fast but I like it. No roaming signal, so far seems good.
It was not added to the nightly built. Thats what I saw on a twitter post.
Music control is a great idea, there is an app on the market call widget locker that does the same with any widget on your phone.
DAMN IT! I'm frustrated for you! Did you get anything figured out?
I accidentally Unrooted and had to start over...
Clockwork is REALLLLLY unstable for me this time around... :confused:
IDK what to do honestly...
UPDATE: Somehow my SDCard became Corrupt... I Re-formated and Clockwork seems a little more Stable...
I lost all my Music though this is a Sad Day :(
I have music controls in my nightly build.
Setting -> CyanogenMod Settings -> Input Settings
Phone rebooted into an endless bootscreen. Pulled the battery and now its fine. Chalking it up as negligible.
For some reason the newest build won't flash for me. :( I think I may go back to stock until this actually reaches beta. Fun way to spend the day though. :)
I have tried all three builds and am actually very happy with the third build. But the battery life made it kinda un-usable for me right now. I may flash back to it really soon though because I love the speed.
On a side note has any one else had the notification bar continually disappear on them?
Battery life seems pretty good for me. Are you using it a lot and it's running it down or is it draining without use?
My notification bar only goes away when I swipe up because it is the option defaulted by the ADW Launcher for an up swipe. You can change that by Settings>ADWLauncher>System Preferences>Swipe up actions.
Johnnie C Mclemore
