Cyanogen is playing tonight! :)
Hmmmm, so an added problem? I dunno if I wanna flash it if you already have seen a new problem. I'm someone who would want to flash every single nightly build but I'm starting to get hesistant.
Me too. I'm checking it out, I made a nandroid so I can just go back to Fresh, it's my daily driver. Anyways, yes it says its always roaming. Not sure I like that, but oh well. I couldn't deal with the no cameras in the Evolution builds, but these really look promising.
The phone is actually not roaming, apparently one of the devs forgot to include a file and the phone says its roaming when it's not.
I said that 2 posts up lol :p
I can't stand this voicemail icon either, I've tried so many things to get rid of it.
I might do it in the morning. Night time is when I start actually using my phone a bit but in the morning is a quiet time so I'll back it up then throw the new one on there then. If anyone else comes across other problems or fixes let us know! This is already looking to be the best ROM for Froyo ever!
Okay, the roaming indicator is an easy fix. Just did this on mine and it fixed it!
Download this file, unzip, and adb push it to your phone.
adb push eri.xml /data/eri.xml
adb reboot
Done!
Notice any changes from the first nightly?
Well for one it's not forgetting my wifi settings randomly, so that's nice.
*EDIT* Okay, nevermind. It still disconnects from my wifi network after ~30 minutes. Have to go in and reconnect manually (says "disabled" instead of "remembered" or "connected" under Wi-Fi networks)
Also, music controls on the lockscreen!
any one who has gotten the magic mouse to work on the first nightly build, any help? cant get it to connect...
Worked fine for me. What I did:
Mouse off
Open bluetooth settings
Turn on bluetooth
Turn on mouse
Tap "scan for devices"
--wait a few seconds--
Mouse should show up, click pair
Enter pin (should be "0000")
Done!
Also note for MM users, I just discovered accidentally: Right click (or rather, clicking on the right side of the mouse) will act as pressing the "back" button!
So what's it like going from one nightly build to the next? Is it seamless or a complete reflash? I know a reflash can be seamless, but is it starting fresh with installing apps and stuff? I asked this earlier but obviously nobody knew because there was only one build so far. :p
Mouse off
Turn on bluetooth
Turn on mouse
Done!
Still no dice...
They posted a second nightly for tonight... the first one wasn't working very well..... flashing the second one now!
Is your Mac (or other computer you use the MM with) on? Perhaps your MM is trying to re-pair with that?
Does your EVO see the MM but won't connect? Or does it not show up at all?
mac not on, MM is discovered, asks for the pin, doesn't connect.
