[CyanogenMod-7 ROM+KERNEL] OM-Mandylion.....01-12-2013..Update
Re: OM-Mandylion....[IHO ROM+KERNEL].....08-20-2012...Update
Trying to get theme Chooser installed but it wont let me, says there is a problem praising or something like that
Any thoughts?
Sent from my VM670 using Android Central Forums
Bankofamerica app is not compatible with this rom. How i can fix it?
Any thoughts?
You don't install it like a normal app. It's a system app so you can either move it to /system/app with a root file explorer or I belive the zip earthnfire provides is flashable from recovery
Is it compatible with other cm7 ov roms?
I see the zip, helps to read huh
Thanks
It is compatible with all roms i tried yet.
Update is now ready, still working on replacing BacksideUpdater and adding some options to Settings for Fastcharging: one or both maybe ready in next update.
Re: OM-Mandylion....[IHO ROM+KERNEL].....09-27-2012..Update
Yes!! The update I been waiting for!! Thanks downloading now!
My phone wont go past the android screen. I flashed your recovery then ran Lesieann's(sp) 3 pass zip and installed this rom.
You need to partition the sdcard to either ext3 or ext4 otherwise it well not boot to home screen, and also under the advance menu option in CWM-Blue-Recovery, there is an option to do a full wipe and prep for ROM update. If coming from another ROM use the "Full Wipe" option this well wipe the same things as Lesieann's(sp) 3 pass zip.
Re: OM-Mandylion....[IHO ROM+KERNEL].....09-30-2012..Update
Updated to reflect USSD-based attacks fix and replacing of BacksideUpdater.
NOTE: Please also download and install the latest CWM-Blue-Recovery because some features that BacksideUpdater had has been removed in IHO Updater.
I received an error when trying to update. When the phone rebooted and said verifying update package I got an error that said (status 0)
Sent from my LG Optimus V running OM-Mandylion using Tapatalk 2
Just ran a download and install test and everything went fine, try downloading and installing again. Plus did you run the update install from BacksideUpdater or IHO Updater?
I used backside updater, where do I get IHO updater?
Lately when when updating to the latest ROM versions several of my system apps have been force closing such as YouTube and Google play store. When I try to launch them they say "application not found" and the YouTube app pops up making me force close it every few minutes
Try doing a full wipe install, YouTube should not be a system app because it gets updated to offend, plus YouTube integrated with other Google apps using the Google Account you have stored on your phone. This does cause it to FC on first boot but should work after everything is re-synced with Google.
Today I carefully followed your update process. I installed the latest CWM-Blue-Recovery successfully, used Backsideupdater to update from OM-Mandylion-20120820, using the recommended option of Automatic Install. It wiped the cache and Dalvik Cache, backed up, then successfully flashed the update. However, the first thing I see is System UIDs Inconsistent (UIDs on the system are inconsistent, you need to wipe your data partition or your device will be unstable. After pressing "I Feel Lucky" (the only choice, which incidentally I didn't feel), the steps were as if I'd bought a new phone. Touch the Android to begin, create a Google account or sign in with current account, etc. I'm getting constant force closings.
There were some changes made to the Recovery to account for some options with IHO Updater. I would do a full wipe then install, but backup all your apps app data and user data (but not the system settings) using Mybackup Root first (do not use Titanium Backup as it does not understand how the sd-ext is linked).
Was DSPManager removed from the ROM?
ahsokacat
