[CyanogenMod-7 ROM+KERNEL] OM-Mandylion.....01-12-2013..Update
Re: OM-Mandylion....[IHO ROM+KERNEL].....09-30-2012..Update
Was DSPManager removed from the ROM?
Sent from my LG Optimus V running OM-Mandylion using Tapatalk 2
No just the Launcher icon no longer should up, it can still be used in the default Music Play app.
An Update to OM-Mandylion has been posted as well as the kernel.
There were some changes made to the Recovery to account for some options with IHO Updater. I would do a full wipe then install, but backup all your apps app data and user data (but not the system settings) using Mybackup Root first (do not use Titanium Backup as it does not understand how the sd-ext is linked).
Yes, that worked! I'll have to figure out how to back up the home screen settings (widgets and icons), but maybe they just always need to be reconfigured. Going forward, do you anticipate full wipes being needed when updating? Thank you very much!
Re: OM-Mandylion....[ROM+KERNEL].....10-12-2012..Update
You know.... I flash a lot of roms but I just keep finding myself coming back to this one. Just want to say excellent work EarthnFire78!
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
very, very good ROM...fastest ROM i've used on this site yet (and i've tried almost every GB/ICS/JB ROM on here) just one problem i'm having. Google Voice Integration app doesn't seem to work. It says it's integrated, but the GV texts don't show up in my stock messaging app like they are supposed to, didn't have this problem on any other ROMs on here....any ideas?
With the new updates we need to perform our own backups?
There is an option in IHO Updater "Automatic Install." All that you need to do is do a backup of your installed app's, although your home screen well be reset.
Sent from my VM670 using Android Central Forums
In the latest build setCPU keeps force closing when I open it
I just downloaded that latest version to test, and everything worked. Is the CPU settings Enabled in CyanogenMod, if so then disable and reboot then with a root file manager delete the setCPU data in the data/data folder.
Just a note setCPU does not understand how to scale the IntelliDemand Governor and well cause it to not scale but to jump to max.
Upload a mod zip for Sprint LS670, no key remapping required. Well have an update to IHO Updater to flash the Sprint-LS670 mod after flashing ROM and well have an LS670 version of CWM-Blue-Recovery up loaded later today.
Cool! The more the merrier :)
The update to IHO Updater well be in a few days, the recovery well have it posted tomorrow morning.
Nice work. Its always nice to give and receive with the sprint optimus s peeps too! If I ever looked back to ginger bread this is what I would flash. :)
tap tap tap
I have noticed in the latest update that the installed apps sometimes disappear from my apps in the Google play store as well as the icon switching between the custom blue icon and original icon.
That's strange... I haven't noticed anything like that
You could have a bad sdcard, that may explain some of the problems you have been having.
A possible request.... I'd love if iho updater were compatible with COT recovery.
If someone wants to do that with IHO Updater then go for, what I'm wanting to do is clean up the interface removing the need to press the menu key.
ahsokacat
