[CyanogenMod-7 ROM+KERNEL] OM-Mandylion.....01-12-2013..Update
Re: OM-Mandylion....[ROM+KERNEL].....11-25-2012..Update
Can I install super superuser on this rom if so how do I without messing it up
Sent from my VM670 using Xparent Pink Tapatalk 2
Superuser.apk is already installed, if you Talking about SuperSU.apk, then no because it conflicts with IHOUpdater and MyBackupRoot.
New kernel is available, see Kernel Change Log in first post for features and changes.
wound up having to reformat my 16gb SD card and partition it through recovery instead of through my PC. I think this will work now for getting the SD card to mount through recovery to flash updates. loving how zippy this rom is, and I like MtBackup Root... no more annoying OK buttons to push.
Thanks your for the positive feed back :)
@ ganggreen30 the Kernel Change Log is in the first post of the thread.
EarthnFire its been so long since I flashed a kernel can u tell me what to do as in do I wipe cache and dalvik? Or what? Thanks.
Just make a backup and flash, no need to wipe anything.
EarthnFire 2 questions 1 I already asked is why when I disable USB debugging my root apps don't work it has to stay on for them to work which is baaad! And second question is the new kernel dated 20121201? Thanks and please help me figure out the USB debugging bug. Not secure.
Update and OM-Mandylion is now stable release 7.2.1
There is no bug with USB debugging, the su binary requires debugging mood to be on for root access.
Re: OM-Mandylion....[ROM+KERNEL].....12-07-2012..Update
I've never heard of this b4 on any rom sorry.
Wrong..
Wrong..
Use the same su binary that is found in OM-Mandylion in any CM7 IHO ROM and USB debugging is required. I use the ICS su binary version, which is larger, please do your research before telling anyone they are wrong, ChainsDD even makes note on this with most CM7 based ROMS using the update 3.1.1 (17) su binary.
I love ur rom don't get me wrong and I am using it but jerryscripts never had to.
That's because Jerry's was using a older binary than this rom is using.
Another thing too, I build from source and could have changed the old su binary code to require USB debugging, though did not but use a prebuilt binary.
Will try this later today. Lots of time as I'm mostly cleaning house and getting ready for Christmas. Hopefully not during the NY Knicks game, though! :) I've been using Harmonia and mrg666's ROMS forever... looks like this one continues along those tracks.
I some was it does, most mrg666 since he was a big help with teaching me how to build a kernel. In about a hour and half well have a fix uploaded, the current one there is a file mismatch in the Settings.apk causing the wrong png images to be used; it does not cause any stability problems, but a mistake I made that needs fixing.
For some reason the screen rotation delays quite a bit. Any ideas?
Sent from my VM670 using Tapatalk 2
Dreamz
