cyanogenmod and wifi connection issues
dms76
282
10
18
Installed CyanogebNid-6.1.0-Inc it will not connect to my wifi router. I keep having the same message appear over and over of connecting then scanning then disconnected then repeating over. The phone connects fine with Skyraider, Virtuous and of course HTC Stock. The router is setup for hidden SSID and mac filtering. I have checked the channels in advanced wifi setup. Could I be missing something else in the setup?
It might be a bad install or your device causing this. I am using the 6.1 stable mod with no problems at all on wi-fi, I have connected immediately to every saved location I have on my phone.
Deleting off phone and forcing a fresh download did not help. I made sure to clear the cache as well.
Sent from my ADR6300 using Tapatalk
TaiTheGuy
