I found that people with the epson panels have a harder time oc'ing to 1.2.
wow, your stable at 1252!!!
tell me how, if you can include your hardware info ect...
Though my quadrant score and linpack score are still higher with 1.15 and 1.19 =P
I did eventually have issues at 1252 Mhz, seemed to run hotter then would freeze & reset.
Backed down to 1152Mhz, linpack went to 1300.
I have a 0002 version with nova screen.
question: all of a sudden my browser doesn't auto for the text if I zoom, anyone know the cause?
I am noob at this android stuff. I installed 5tar V1 version but every now and then my reboots by itself. Could this be because I am running cm6 nightly 8/11? Sorry in advance if this has been posted before. By the way dx3 this is an awsome power up. Thanks
Just Cooked 8-13 Nightly
Apps Are Crashing Left and Right...
I need to keep workin on this...
This Source that was released is my own personal hell
Did you check off the setting to auto resize in the browser?
Somewhere in cyanogen mod settings
Yes the auto-fit is still checked. I flashed the 8/13 nightly w/o D3x kernel hoping to fix it and it still will not auto-fit?
you were able to get 8/13 to work with my kernel... lol I cant even do that![]()
No not your kernel, did not have time last night. I'm just on the 8/13 nightly.
Any other suggestions? Thanks.
Ok so now there is another issue? Re-flashed back to 8/11 nightly fine then proceeded to flash the D3x kernel with clockwork like I did the other day but now the phone gets stuck on the cyanogen mod screen.
The swirling line gets stuck. Starts from around the 3 o'clock position and stops at the noon position?
Waiting for 10 minutes, then pulled battery and repeated the process but same results?
For some reason I cannot get the 8/11 nightly to work with the D3x kernel now?
You need to do a data wipe / Cache / Davlik
Then restore then flash the kernel
I did do the wipes, tried clockwork and amon RA. I did it yesterday with no issues but now it does not work?![]()
