D3x CM6-5T4R
Preferred Launcher?
  • Total voters
Her crashed because of something On the sd card... But your choice
Sent from my uber hax Evo...
i'm back on RC2 by itself with no Kernel lol...i'm thinking i might be overloading something...i have a couple appointments tomorrow but after them i'll fix my problem...just wait :)
well...i'm trying to fix it via my laptop now...which has windows 7 and i can't get sdk/adb to work on it! it was so easy to do on my pc with vista...i downloaded everything it said to and when i do "adb devices" in my cmp promt it can't find anything :(
Powerup rocks man! Was getting quadrant scores over 2000 :) New icons in the status bar are sweet.. great job putting this one together!
its over 2000! (not quite perfect but how about a little love ;) )
You want it too?!? lol
Do you know about the whole Partitioning thing and krap for Snap V7?
Check your Box I'll Link you...
Could of Sworn you were a Sense dude...
I was running RC2 with Snap 7.0 without the SD card partitioned.. everything worked great. I restored to an RC2 with the stock kernel, copied off my entire SD card to my computer, installed AmonRa.. did the partition.. rebooted, copied back all my SD card contents, booted into recovery and flashed the new D3X Spin kernel.. and been loving it since. No problems!
NICE!
Glad to see that worked for you...
oh...i didn't think it would work with this rom at all lol...i think i have the APK file from when i got it before lol...let me try it...i'm on the normal RC2 righjt now with out the kernel...i'm going to load that back too..
does the camera on ur work with this kernel? mine kept force closing yesterday
Of course my Camera works...whats up with your Gimpy Evo dude... lol
So, dumb question. Where do I put swype on my sdcard to make it work and how do i install it? i know how to change the input method but not sure if there is an install routine for the .apk
put it anywhere on the SD card...i put the APK on the root of my card...open ASTRO manager and click the file and it'll ask how you want to open it and use the install manager or whatever it is then follow the steps
1075dn
