ARCHIVED: [DEAD ROM] LEGO-ROM-v2
Status
Not open for further replies.
Oh yeah, that's our "midwinter handwarmer" process in action. Nahh just playing lol.
Actually LEGO ROM and ThundeROM are very similar in architecture, almost identical leave the kernel. Are you sure it wasn't an application in the background running the CPU? What was your exact setup?
In my experimentation to narrow down the issues over the last couple of days, the only thing ive installed from the market is Hotspot Widget and SMS Backup/Restore. Running stock kernel with Two Point Two.
The problems I was having such as massive battery drain while tethered were attributed to having JIT & HW enabled. The system-wide lag I was getting in TR 1.6/1.6.2 has not showed up in Community, nROM, or LEGO so I don't know where that would have come from.
Thanks Cordell, glad I asked now, I was going to guess 804000 :-) As for the quotes, when I CAT scaling_governor it came up with interactive. Does that mean it worked? Sorry took me so long to respond, work has been nuts!
Yes, if you CAT and interactive came up you are set. One thing I notice is after a reboot the governor like to set back to ondemand. My reasoning why this happens is because I use Overclock Widget rather than setCPU. Another thing that was messing up, when I moved dalvik cache to SDcard it would reset my MIN and MAX settings to stock upon reboot. That was with both setCPU and Overclock Widget.
Have you tried pin or password mode? Give those a shot
Found this issue in nROM, but entering a failing pin will cause reboots. Just tried for the sake of science! Given this, I'm sure a failed password will reboot also.
Is the reboot mod a separate file you all inject into the ROM? Or is it a tweak in the framework-res.apk? Since I have a blizzard out here and no work (quite amazing really) I might take a peek into that apk to see what I can find.
@ ANYONE Here's a flashable zip to boot 806max/245min.Im going to attach it here for now i need someone to try and boot this. It should be my kernel ill make one with zefie's kernel in just a little bit. I need someone that knows they can boot 806 to boot this and just double check to make sure under "about phone" it says beezy and not zefie.lol Sorry i might have mixed kernels it won't do any harm.
Forgot it's too big to attach so here's the LINK!!!
If you can't run/boot 806 don't try flashing this.lol
I don't use a lock so im not sure,but the mod is done to one of the apks i beleive it is the framework-res.apk. Im not very good with that part of modding so im just going by what i remember and my memory isn't that good.lol Don't feel to bad im down in Illinois the whole town is shut down here too.:'(
Booted right up, and you got correct kernel/beezy. ;)
edit...has sprint splash screen :(
Booted right up, and you got correct kernel/breezy. ;)
Thank you. It's 'beezy' not breezy right?lol j/k The Sprint splash is actually part of the ramdisk,i see everyone seems to want that gone/removed.Ill whip together some new zips of both zeife's and mine that have the splash removed.
Thank you. The Sprint splash is actually part of the ramdisk,i see everyone seems to want that gone/removed.Ill whip together some new zips of both zeife's and mine that have the splash removed.
I wish we had Fastboot capabilities, though I guess we could use a custom splash image by naming it the same as one of sprints images and rebuild boot image? To much effort for 5 seconds! lol
Thanks
My bad beezy, its still early, lol. Can I blame it on fat fingers? :)
Thanks
That doesn't work!!!! black, red, black, red, black, red ..... right beezy?
FYI - Those were the images we used while testing that theory. A black image, then a red image ... so on and so on
Thanks
That would be nice.We got a custom boot animation that is for LEGO just ive been so tied up trying to do figure some other things out that i haven't got around to put it together. It's on the list of things to do.lol
THIS WILL EXPLAIN.
Reactions: xtacocorex
Haha, also in IL (Normal). I worked overnight last night (I'm the po, lol) and you would not believe the idiots out driving around last night getting stuck. Had fun driving around in 4wd all night though. Everyone else is off today but we are considered "essential employees"
Sent from my Veganized Gtab using Tapatalk
LMFAO, Peoria,;) I know i seen the idiots and 4wd is the only way to go around here.
Same format, sizes, and quantity?
I tried all that fun stuff. You have to put a blank as more of a place holder so that the phone will stay powered off then add your boot animation to the rom.
Ever since I started running LegoROM my battery life has went down and it shows my Time Without a Signal is 50%. I have not been losing signal as I am right down the road from a Sprint tower. I also ran nROM for about an hour yesterday and noticed the same thing. Any ideas?
Try updating prl/profile then if it still happpening toggle airplane mode on/off after a reboot and see how things go.
Flashing now...
Beezy@beezy1
All good!
Status
williestringfield90
