ARCHIVED: [DEAD ROM] nROM v1.6.3
Status
Not open for further replies.
WTF HAX. Somehow I deleted ES file explorer. Uploading an updated version now.
Thank you for the clock widget. It is the finishing touch that I wanted on my phone. Props to you bro.
Just flashed the latest nROM and its great, but for some reason I can not access Settings. The setting icon is deleted from the app drawer and when I long press the home screen to get to setting that way, I click the icon and then nothing happens and I just return to the homescreen.
Just wondering if this has happened to anyone else, I'm going to wipe stuff and reflash and see if that takes care of the problem..
I'm rolling good so far, in fact I just accessed the settings to check something.
I don't know what the deal with that was but I just restored a nand backup, then flashed the updated nROM and everything seems to be working as it should. Good job yall!
Found a bug the stop button on my browser force closes my browser every time and I have tried installing 3times
Considering that the update doesn't touch the browser, I'm thinking that something else is causing this. Mine works fine. Try flashing v1.2 then v1.4.
EDIT: If you still have problems I'll put together an update zip that you can flash to replace your browser to see if that helps. For now you can press menu -> stop though.
EDIT: Flash the attached file via recovery.
Nick, did the update touch the Market at all? For some reason all the apps I've installed before the 1.4 update aren't listed, but the one I installed post update is the only app there.
Not a huge deal since I have a Titanium backup of them all, just wanted to give you a heads up if it truly is an issue.
Is the ROM Kitchen that you use the one linked in the XDA thread that dsixda started?
The market wasn't touched. Maybe that's from clearing dalvik-cache or something :P idk.
And yes dsixda's HTC kitchen.
my phone went and died and now it wont charge and my phone is on constant restart....it keeps shutting off and on....please have a fix :( i need my phone!
You need to be specific. What did you do before this happened? What exactly is it doing now.
okay so all day my phone would randomly either restart to the lg logo or restart to the nRom loading bar. I didnt think anything of it until my battery went dead...i put it on the charger when i got home and it wont charge and now it keeps rebooting to the Lg logo or nRom and when it loads back to the lockscreen after about 15 seconds itll reboot to the either those same places again...
Can you get into recovery? And were you overclocking?
Status
redmercer
