ARCHIVED: [DEAD ROM] nROM v1.6.3
Status
Not open for further replies.
I've been using nRom for a while and haven't been able to update the PRL. I'm on version 60675 on VC. Do I need to update?
You two need to test this out for me. Let me know if everything works
*WARNING*
This is for VC ONLY. This is also a test build.
Download here
Reactions: jrsndr
*WARNING*
Download here
Downloading now. I'll let you know...
PRL update worked just fine. My PRL has been upgraded to v 60676. Thank you!
Okay, ran the PRL update again and got ! Finish, XPT open PPP failed(20). Please try again later. Don't know if that was because I upgraded successfully the first time or if I didn't have enough signal. I have 1-2 bars fairly consistently.
Went outside for better signal and got same error....
Well if you are already updated I don't think you need to reupdate lol
My PRL was already up to date. I was able to at least attempt to update the PRL and Profile.
Thanks.
I think your ROM has 5.1.0 in there although 5.2.0 seems to be defective so I guess it's okay. :)
Also was wondering - for the dialer, when a tab is selected, is it supposed to turn all white, or is this by design?
Oh you're right, I just went into the market and maps has an update, will be in the next release.
The dialer tabs turn white just by default :P the white text on white is kind of weird but I never really thought about changing it.
Does the 5.2.0 update work for you?
After installing it it doesn't seem like any searches work any more.
Try searching for something and nothing will happen... :(
Yeah I updated and it's broken for me too :P just revert and you should be good. Must be a bug with the new version.
Status
DannaOgle83
